advice on painting parts
Old May 26, 2009 | 07:57 PM
andyskate's Avatar
Default advice on painting parts
after i have my fairing and tank painted. . shall i put a coat of clear coat on first and then my decals or does it matter? should i clear coat of stickers on plastics or just the gas tank? thank you!
Old May 26, 2009 | 08:23 PM
Honda_Runner's Avatar
its personal choice. I myself, prefer to lay the decals down and then clear coat over the top. Only thing is you have to make sure you really like the decals cause they will be on for a while.
Old Jun 2, 2009 | 03:44 PM
stang68's Avatar
ya put your decals down than your clear coat ..... like when your washing the bike the towel will not chech the edge of the decal or be pulling them off
Old Jun 2, 2009 | 11:13 PM
Squamish CBR's Avatar
Apparently decals designed to go under clear coat are very very thin. If they are thick, you must use a ton of clear to seal the edges. I had mine lift on the edges requireing a re-clear.
Old Jun 3, 2009 | 05:45 AM
patso's Avatar
Default I have a problem priming upper?
Sorry to jack the thread. Just a quick question?
I have one piece to go and ready to ride, the left upper where cave in above the turn signal is won't prime. I mean the part where the air flows into a hole. I prime it and it just cracks the prime and leaves me with a bad coat. Any suggestions?
Old Jun 3, 2009 | 08:49 AM
hopz's Avatar
First off, I am not a paint expert but I have painted bikes before. Sounds like something has penetrated the surface and it needs to be cleaned well before priming.
Try sanding down again and cleaning with good solvent.
Old Jun 3, 2009 | 12:35 PM
Browntowns20s's Avatar
if its abs plastic you need to put adhesion promoter on it or it wont stick worth *****. dupont makes a spray can application for it. thats what i use at work and we love it
Old Jun 3, 2009 | 01:23 PM
patso's Avatar
Default i willl try that
Thanks, ya like i said, it is fine everywhere except for there. The primer looks like a big crack.
I will def try that though
Old Jun 4, 2009 | 07:44 PM
99LS1's Avatar
You can put stickers down and clear over them but remember you might fall into a adhesion problem. Paint needs to be approximately 600 grit to have clear stick. Think about the shiny sticker your putting on.
Just a suggestion. Thats why I am putting mine over the clear.
Old Jun 4, 2009 | 09:16 PM
well the best way to do it would be take the tank, clear it. let the clear dry, take a gray scotch brite and scratch the whole tank down again, then place your sticker, then scratch the sticker with a yellow scotch brite (gray might be ok if your gentile) then put adhesion promoter over the whole tank and pound another three coats of clear on there. let it set up for the cure time, then denib, wetsand, buff to perfection. make sure you dont use a no bake clear unless you have a paint booth with a bake cycle, if you do it will take like a week until the clear is hard enough to buff. once the paint is fresh and buffed do not wax it or anything for a good 30 days-usually longer. then you will have a great paint job that will last you till you hit the dirt
oh and ps, when you scotch brite it make sure ALL the shiny is gone!!!! if you dont guess what, your paints gonna flake off. also instead of a gray and yellow scotch brite you could use a wet scuff compund for your paint prep.....and make sure you clean and tack everything off or your paint job will look like *****!!!
Last edited by Browntowns20s; Jun 4, 2009 at 09:18 PM. Reason: forgot some important details
bubbamcf
Jul 23, 2012 05:03 PM
jonnym61
Mar 10, 2010 03:50 AM
playero_loko
Jul 28, 2009 03:14 PM
OsinO
Apr 11, 2008 04:49 PM
FireStourm
Mar 21, 2008 08:52 PM
