Adaptronic System base map?
Old Jul 30, 2011 | 07:06 AM
JCUMotorsports's Avatar
Default Adaptronic System base map?
Does anyone happen to have a base map (.ecu file) for a CBR600F2 Adaptronic aftermarket CPU? Or anything similar? The engine we are using used to be a carby driven CBR engine, but it has been modified with a custom EFI system. Anyone had any experience with anything similar?
Old Jul 31, 2011 | 12:09 AM
adrenalnjunky's Avatar
The CBR F2's talked about in this forum are for the 1991-1994 models. No EFI or CPU for our bikes, just a simple carb and ignition control module.
Old Aug 1, 2011 | 03:40 PM
JesseAwesome's Avatar
You missed those details
I've never heard of anyone doing the work you've mentioned. Most people don't sink that heavy of an investment into these bikes. Let us know what you find.
Old Aug 2, 2011 | 05:45 AM
How about fitting a F4i EFI and intake manifold to a F2 head? Has anyone ever heard of this mod being carried out? Is it even possible?
Old Aug 2, 2011 | 06:13 PM
Not that I've seen.
Old Aug 6, 2011 | 03:40 PM
jtkardel's Avatar
You'd be better off asking the F4i guys. I'm sure it could be fit, but I don't know what the F4i ECU will need to work with the F2 mill. I doubt an F4i ECU will work well without an additional ECU. The F4i is a significantly different engine, with a more aggressive cam and timing profile, probably won't work well with a F2. A megasquirt ecu or something else equivelent., a wide band sensor and some dyno time is all I can think of running decently. That said, if you have a working EFI system, something from a 599, FZ6 or even an F4i wouldn't be a bad start.
Old Aug 7, 2011 | 11:13 AM
squale147's Avatar
July 2013 ROTM
never heared of this but does sound intresting,,,keep us posted
cc rider
Mar 30, 2013 08:39 PM
brody1124
Jul 29, 2010 04:12 PM
iceman423
Jan 7, 2010 07:17 AM
Blue Fox
Oct 19, 2007 03:21 AM
