93 F2 with a bad problem
Old Apr 2, 2007 | 04:03 AM
Dodger's Avatar
Default 93 F2 with a bad problem
So I just got this 93 f2. Ot has 13000 miles on it.....
I have put new ngk plugs on the bike......
The bike will run flawless for a day and then out of no where bog down and start sputtering, and die, with no hopes of re-starting......then other times when it bogs down, you can re-start it and its ok......then it will run fine for a day, then the same thing happens with it sputtering again.....it is my understanding that the bike had been sitting for a while when I got it.....is it possible that I need to drain the tank and start over, or does it seem like the carbs may need attention? I have only ran about 1 full tank of premium fuel through it since I got it, and I really need to get this issue solved!!
Old Apr 2, 2007 | 11:22 AM
Kevo's Avatar
Default RE: 93 F2 with a bad problem
when you took the tank off to put the new plugs in you probably kinked the fuel line it might not look kinked but if is bent just slightly to much it can be very big pain in the a**
Old Apr 2, 2007 | 12:32 PM
TennesseeCBRF2's Avatar
Check the fuel line for kinks, as said above. I would also give the carbs a good cleaning since it sat for a while. If there was gas in it while it sat, it coulda gotten all gummed up.
Old Apr 2, 2007 | 02:03 PM
Dodger's Avatar
well it was doing this before I changed the plugs, and that's what prompted me to change them...
I have noticed that if I put some gas into the tank it runs great but when the level gets to half or below, it starts having these symptoms of not running well at all....
Old Apr 2, 2007 | 03:08 PM
lee1rbc's Avatar
Sounds like maybe a problem with the petcock valve? I would drain the tank and take the valve off and clean and inspect it.
Old Apr 2, 2007 | 03:45 PM
rcd33's Avatar
might check your fuel filter.. maybe its clogged. try running some fuel treatment in your gas. there are millions of brands out there.
Old Apr 3, 2007 | 03:21 AM
Dodger's Avatar
yea cool cool, thanks for the suggestions.....after talking to several people today at work, I think Tomorrow morning Im going to take off the tank and drain it, also remove the petcock valve and clean everything out......hopefully this will take care of the issues
Old Apr 3, 2007 | 01:22 PM
Dodger's Avatar
SO................I took the tank off, removed the fuel switch and such......
I drained the bowls on the carburaters and a buch of rusty nastiness came out.....so I think I have found the problem!
Tomorrow I am off all day so I will flush the tank and such......
Does anyone have any past experiences or advice on flushing the tank and so on??
Old May 28, 2007 | 09:37 PM
Tony Wilkinson's Avatar
Did you get this problem figured out? I am having a similar problem.
Old May 31, 2007 | 07:13 AM
VBCane's Avatar
I am having the same exact issue to, must be something going around. I'm also interested if you found a cure.
