92 F2 Start Problem
The problem started today when i noticed that when im in First gear it wont start...? Once i put it in Nuetral then it would start but it also starts in Nuetral without me holding the clutch in...?
RE: 92 F2 Start Problem
My bike starts in neutral with no clutch...BUT it also starts in 1st (or any gear) with the clutch!
Yeah i dont know whats wrong with it?
Is your kickstand down?
Your bike should start in neutral with the kickstand down, or in gear with the clutch pulled in. If there is any deviation from this I would check the switch for the kickstand because thats probably the culprit. |
Your bike wont start in gear with the kickstand down. Hope it is as simple as that, which I bet it is.
Yeah i was thinking the same thing but what exactly am i looking for and where does the kickstand kill switch go to so i can check it out.
I'm sorry, did he answer the question?
The bike is designed to not to start in first gear, if the Stand is down. Is the stand down? If it is down, then this is by design and nothing is wrong. Matter of fact, to prove the point further, after starting, putting the bike into gear with the stand down, should, by design kill the motor. |
dude i gotcha ya i know. i dont think your understanding MY problem. The kickstand is up when i try to start it in gear the bike wont start.
Yeah, so why don't you make sure that the switch is working properly and not giving you a false-positive. Since the switch is DESIGNED to produce the kind of results you are having when the kickstand is DOWN, maybe if it is faulty it is causing your problem. sheesh.
No i completly understand what your saying about the switch an all. But since i dont really know a whole lot about how to fix something like this im not sure what im looking at. So if i can get some guidence that be cool.
