91' CBR F2 Problems
Old 04-29-2013 | 10:40 PM
Mik_Lewis's Avatar
I'm guessing that is code for "you got a really good deal" lol
Old 04-30-2013 | 10:24 AM
Mik_Lewis's Avatar
I found an 04-6' rectifier for a r1. Does anyone know if I will be able to use it as a replacement?Name:  null_zpsd83d128d.jpg
Old 04-30-2013 | 11:43 AM
Mik_Lewis's Avatar
Here it is. I bought it for 50$ and it has 5 connections so I'm guessing the the 3 to the left are my yellow connections and my others are my positive and negative?
Old 04-30-2013 | 11:49 AM
74demon's Avatar
Get a wiring diagram for an R1 and compare.
Make sure it fits under the fairings. The GSXR unit is a more popular retrofit.
Old 04-30-2013 | 12:00 PM
Mik_Lewis's Avatar
I have to find a new spot to mount it. I'm pretty sure it's the same diagram as this this Yamaha r/r
Old 04-30-2013 | 12:29 PM
Mik_Lewis's Avatar
Found my solution. Name:  null_zps8b8f9a7a.jpg
Size:  28.4 KB where can I get the terminals from? That way I don't have to buy the harness and cut up my own
Old 05-01-2013 | 08:25 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
Even if you find the connectors, you'll still have to splice into your wiring harness... I don't know what most guys use for the connectors, when making this swap - I assume they find a full or partial harness for the same bike the R/R is from, and cut that portion off.
It might be simpler to just go with an aftermarket R/R, that is designed for the F2... plug-N-play.
CBR 900 RR*Rectifier Voltage Regulator
Regulator Rectifier CBR600F2 Honda
Those are just a couple of links I found really quick - there's a few more out there.
Old 05-01-2013 | 09:21 AM
Mik_Lewis's Avatar
Actually I got it to work fine. I went and picked up some female connectors,spliced the stock wires,crimped the connectors and then it was just plug and play. It seems to be like that solved the problem.
Old 05-01-2013 | 09:52 AM
JNSRacing's Avatar
Sweet, glad to hear it.
Old 05-01-2013 | 12:30 PM
outsider's Avatar
Wow, that's you? Great pic......
Quick Reply: 91' CBR F2 Problems
