OBD connection / Plug
Old Dec 1, 2017 | 06:31 AM
dbeerd's Avatar
Default OBD connection / Plug
Hi Guys, Do you guys perhaps know what OBD connection / Plug the 2012 Honda CBR 600 F uses. I have OBD2 device as but I can’t find the Plug on the Bike
Old Dec 1, 2017 | 08:22 AM
CaBaRet's Avatar
Hi matey , are you talking about the DLC (Data Link Connector)
Old Dec 1, 2017 | 02:11 PM
dbeerd's Avatar
cool....is that what honda calls it......can a DCL cable connect to a OBD unit
Old Dec 2, 2017 | 12:26 AM
CaBaRet's Avatar
Hi ,did have a Triumph that an OBD would connect to , but not on these , what you may need is this , if you want to go that far in , but just bridging the DLC will bring up the codes you will need, maybe with using a Power Commander 5 will help.
https://honda.snapon.com/HondaCycle/...temId=47541382
But quite pricey
Old Dec 2, 2017 | 04:16 AM
dbeerd's Avatar
nice, thanks bud. what wires do i bridge out? where can i find a list of error codes?
Thanks for all your help
Old Dec 2, 2017 | 05:41 AM
CaBaRet's Avatar
Hi matey, you'll need to raise the petrol tank, look for the DLC ,it should have a red cap on a 4pin connector, use a paperclip or piece of wire and bridge the Brown and Green wires,make sure the bike is on the side stand and in neutral and Kill switch on run, then turn on the ignition and watch the fi warning lights for codes for long and short flashes they are your codes
Old Dec 2, 2017 | 12:31 PM
dbeerd's Avatar
Thanks Bud
Old May 29, 2018 | 07:53 AM
CBR600FA's Avatar
dbeerd, I know its an old post but did you find the connector?
I recently installed a gear indicator on my bike the the connector was behind the right side fairing with red cap
Old Apr 24, 2020 | 07:17 AM
Frankie Hannon's Avatar
Default Cbr600F gear indicator
mate please tell me your talking about a cbr600F? I can not for the life of me find this dam plug for my indicator to go to. Any help much appreciated
Old Apr 24, 2020 | 07:23 AM
Default Cbr600F 2003 gear indicator plug
Please help me find this dam plug on my bike. Got the eBay gear Honda indicator says it plugs into my ecu it does and it’s also got a random green wire hanging from indicator I guess is the ground? But it ain’t coming on and I’m getting stressed.
