wheels change !!!!!!!
F2 and F3 wheels have a larger diameter axle, so your options are to either bore out the axle mounting holes, swap the bearings for smaller ones, or a swingarm swap for your rear wheel. up front, you would have to either find a front wheel that accomodates a speedo sensor, OR do a fork swap, as 90% of wheels out there use a larger axle than our 600F's do on the fronts as well.
I'm looking into a 98+ Katana rear wheel swap, and potentially some way to swap the front end over too to retain the wheel driven speedometer, and dual discs, while gaining a little larger wheel. I know the 98+ Katana rear wheel uses the same diameter axle, so bearings are alike, you'd only REALLY need spacers, and the brake caliper, bracket, and rotor to use them, as the Katana uses a larger brake rotor.
