WHAT IF??
Old May 2, 2008 | 02:08 PM
newnut's Avatar
Default WHAT IF??
What would happen if my wiring shorted on the frame? i suspect that may have happened before i picked the bike up as a new battery does nothing!
Old May 2, 2008 | 04:07 PM
Gogar's Avatar
Default RE: WHAT IF??
Well, if you have a voltmeter that's good. Take the battery out and make sure it is charged first. Sometimes when you buy a new battery you need to throw it on a charger for a while.
Then, check your fuses. The fuses are behind the left side 'upper inner' in front of the gas tank. You'll need a 5mm allen. Make sure all the fuses are good, and go from there.
Old May 2, 2008 | 04:17 PM
newnut's Avatar
hi there, check and check! both those i've done, any other ideas? it has a new wiring loom already too! thanks.
Old May 2, 2008 | 09:29 PM
2bikes's Avatar
I would suggest checking all your connections. Battery terminals, starter connections, key switch terminals run/stop switch, ect.
Will it do anything? Lights come on? Clicking? Anything?
