What grade Motor oil?
RE: What grade Motor oil?
drain plug under left side of oil pan.
i just use fram filters. i had a K&N but expensive.
i use semi-syn 10-40. i change oil regulary so i just get the basic stuff, nothing fancy.
remove left side fairing to remove filter. it's easier that way. or you could leave fairing on and remove filter between the middle sets of header pipes. i tend to remove my fairings just to check other things like coolant, battery terminal corrosion, etc.
don't know. you'll have to reference it in the store catalog, or go to frams website: http://www.power-21.com/HoneywellPow...cycle_0126.pdf
