what do i do
Old Aug 12, 2013 | 05:41 PM
hunt3rm008's Avatar
Registered Users
Default what do i do
I have a 1990 cbr 600 f and I Bought it for 1250it is in really good shape and looks good. A few weeks after I bought it it died on me and I can't figure out its problem. It has to do with the fuel system because it will not pump Out gas but when I plug the pump straight to a battery it pumps. I try replacing the relay but it still does not work. I just want to get rid of it. Should I try selling it as Is on Craigslist or should I try parting it out. What do you guys think. If I try to sell as is what would be a good price?thank you
Old Aug 13, 2013 | 08:15 AM
90cbr600f's Avatar
Registered Users
Did you check your fuse it should be a 10 amp.
Depending on condition I would try and get atleast 1000-1200 for it but if you could getnitnruning cheaply I would definitely say 1200.
Old Aug 13, 2013 | 10:26 AM
drakito's Avatar
NON running sold as a whole bike? Expect about $250-300 for it.
Parting it out will take some time as ebay is flooded with parted it out Hurricanes at the moment.
Check your electrical, if you have a meter make sure you have both +12V and ground.
Then check your fuse box. It is on the front below the left handlebar, underneath the plastic cover. If the fuse is good pull your seat and tank off and make sure all the little plugs under there are plugged in.
Old Aug 13, 2013 | 05:43 PM
TahoeRider's Avatar
It should be an easy fix if you have a multimeter and a little time.. even a test light would probably be enough to at least trace the circuit back and see where you're losing power.
I would agree you probably won't get more than a few hundred for it in non-running condition.
