wanting to see if anyone could help
Fork conversion All ***** Racing
Your bike uses a 26-47-15 on the top bearing and 30-55-17 bottom bearing. So any bike that also uses those bearings for the steering stem would directly swap. If the neck length or something is different - AllBalls won't list it.
If you wanted to use a bike's front end that doesn't quite match up (like a GSXR), you'd need to buy their conversion bearings to make the front end fit (even then it's not that expensive).
I'd recommend finding a bike that is newer, but similar weight and fork length. A GoldWing front end might fit - but I'm not sure that'd be a very productive swap, know what I mean? I'd try to find a 600rr front end or something. Contrary to popular belief, they're not selling for all that much more than a good conditioned older bike (like an F2).
I don't want to buy a whole bike. I don't have a lot of money. Where would be a good place to start looking for a front fork. I'll need to buy a rim and everything. If I upgrade can I put a stabilizer like on the newer bike? I am new to bikes I can build a car but need a lot of help with this build will be putting pics soon.
your right you would need a complete front end,stem, clamps,wheel and discs callipers and master cylinder (to match to the callipers), have you thought about an up grade from some one like ISR Brakes or the like, your other option could be calilpers and master cylinders from another bike that has the same mountings, have a search online to see if anything is a direct swap.
ISRs would almost require a second mortgage on the house!
ebay and craigslist.
You could just try a newer, bigger master cylinder for the brakes. That with stainless lines and a good bleed would probably do it! ANY 7/8 bar Master Cylinder will fit - that's any sport bike's master. For example, I'm running a Duc 1098 master cylinder on my bike. It's probably a little too big for your bike, but I saw a thread where a 'cane had a 929 M/C on it. Those are only $50 or so on ebay.
The Hurricane brakes are pretty good when working properly. You would be money ahead buying a set of used rotors on Ebay, new pads, rebuild the calipers and MC and you should be good to go...and stop.
You could put a ton of money in the other options and since you are new to this you may not even like the bike...just doesn't make dollars and sense IMO.
