valve question
Old Dec 18, 2008 | 07:01 PM
Hurricane rider's Avatar
Default valve question
Does anyone know what would cause my valves to just suddenly go from properly adjusted to being either too tight or much too loose in a matter of 1000 or less miles? I know I'm tightening everything right, and its not working its way loose I dont think, but I'm wondering what could be causing this.
anyone got an idea? I'm putting the valves at .006 on the intake and .008 on the exhaust side.
Old Dec 18, 2008 | 08:08 PM
thrasher572's Avatar
Default RE: valve question
Are the cams in good shape? And the journals?
Old Dec 18, 2008 | 09:52 PM
They look good from what I looked at when I serviced it yesterday. although I'm uncertain as to why they'd just go so far out of spec so fast.
Old Dec 18, 2008 | 09:57 PM
Is there carbon on the valve seats? How far were they out of adjustment? Noisey?
Old Dec 18, 2008 | 10:02 PM
the exhaust valves on the #4 cylinder were pretty out of spec, to the extent of a significant power loss, and it was pretty noisy. how would I determine if there is a carbon buildup on the seats?
Old Dec 18, 2008 | 10:09 PM
That means pulling the heads. Before you go that deep, are you letting the engine cool off completely before making the adjustments? Working on the engine warm can throw off the measurements.
Old Dec 18, 2008 | 10:18 PM
yeah, I was starting off completely cold after letting it sit pretty much overnight. I"m not sure I'm wanting to pull the heads off yet, or I feel I may as well just rebuild the whole motor.
Old Dec 18, 2008 | 10:26 PM
I cant remember if you are running stock exhaust system... Burnt exhaust valves or seat damage may be present. I had my valves adjusted about 30,000 miles ago...they dont usually change dramatically unless there is another issue.
Old Dec 18, 2008 | 10:29 PM
I've got a full D&D system on there, no jet kit. if that helps any.
Old Dec 18, 2008 | 10:40 PM
No jetting changes... That bike may be running lean then. That points to burnt valves or seats, especially with significant power loss. Maybe someone else has some other ideas, but I think the head needs to come off.
