Tire Size Question..
Old May 17, 2009 | 08:43 PM
Zach's Avatar
Arrow Tire Size Question..
What Size Tire Can I Go (Biggest Without A Problem) For These Stock Tire Size There Isnt Much Of A Choice. So Wondering What Size You Can Put On Stock Rims..Looking For Some Dunlops..
Front tyre dimensions: 110/80-17
Rear tyre dimensions: 130/80-17
Old May 17, 2009 | 10:26 PM
virtusjunxit's Avatar
Default Tire Size
Edit: This is in regards to your rear tire.
I just recently replaced mine and had this same question.
We're a bit limited with the Hurricane due to F1 rear swing arm. I read in a forum that you can convert it to a F3 rear swing arm for a larger tire, but that of coarse is going to require some work (might as well go Street Fighter at that point (what I want to eventually do)).
140/80-17 Is what I have.
The default tire size is a 130/80 -17.
Old May 17, 2009 | 10:29 PM
Zach's Avatar
have any problems with that 140 tire with the stock swing arm im going to keep it stock swing arm.. any pics thanks
Old May 17, 2009 | 11:51 PM
They're not much bigger at all, really and you're safe with the OG swing arm.
Here you go:
Old May 17, 2009 | 11:54 PM
Zach's Avatar
Nice.. going to be looking for one here soon.. nice bike how did u put ur rear fairings on without that side cover to hold that bolt that u turn with a flat head? hows ur bike sound have any clips?
Old May 18, 2009 | 12:04 AM
No sound clips, sorry.
If you're referencing the middle screw, it's actually not needed and just sits freely (the other two fairing screws for the back pieces hold it in fine, no wobble).
Here's some pics:
Under the fairing:
I am in the process of converting this over to a Street Fighter piece by piece.
Old May 18, 2009 | 12:06 AM
Zach's Avatar
nice.. them plastic things that sit inside rubber one of mine are broke so not sure if it will hold tight.. thanks for the pics..
Old May 18, 2009 | 09:42 PM
Zach's Avatar
does that 140 rub the chain? so thats the biggest u can go right..
Old May 18, 2009 | 10:54 PM
Zach's Avatar
Also what is the differnce from a 140-80-17 to a 140-90-17 would the 90 fit my stock rear rim? thanks
Old May 19, 2009 | 03:48 AM
tripicana's Avatar
i have dunlops 501's on my bike. 140/80/17 on the rear. i wouldn't go larger than an 80 series tire beause you start to mess with the geometry of the suspension from the taller tire. there is plenty of clearance between the chain and tire, hell you could probably squeeze a 160 tire on there, but it just wasn't designed for it. stick with a 140/80, you'll be pushing the limits of the bike just to use that tire.
