Tire pressure..
Old 09-15-2012 | 09:56 PM
deezul's Avatar
Default Tire pressure..
i checked my tire pressure today and it was pretty low.. front was around 15psi and the rear was at about 22psi.. i filled them up to about 35psi in each tire, but im not sure if this is the best pressure or not..
what tire pressure should i be running for normal riding?
Old 09-16-2012 | 04:58 AM
RedBaron's Avatar
36 front 42 rear is factory pressures, and I personally think that gives the best balance of tire wear and performance on the street, but you'll get mixed answers on this one.
Old 09-16-2012 | 06:08 AM
HenryM's Avatar
Check what it says in the hand book if you have one, that's always a good starter for 10. You may still have the factory sticker on your chain guard that gives you the recommended pressures.
Do 600s run at 36/42? That's certainly correct for the 1000F.
FWIW, I've been running my BT023s a bit harder lately. I find it makes the steering a little lighter and more precise. Front +1.5psi, Rear +1psi.
Every tyre has it's own characteristic though. Experiment a bit.
Check pressures every week at least.
Old 09-16-2012 | 06:35 PM
deezul's Avatar
unfortunately, my bike doesnt even have a chain guard anymore.. but im going to try the 36/42 and see how it feels.. it already feels a billion times better than it did with the low pressure
scorpionvmu
02-19-2011 12:00 AM
phillycbr
10-20-2009 08:56 PM
Ripper44
02-13-2007 07:49 PM
ameersak
10-27-2006 01:48 PM
canadianF4i
09-12-2006 03:06 AM
Quick Reply: Tire pressure..
