Tach reads double intermittenly!?!?
RE: Tach reads double intermittenly!?!?
Tachometer Testing...
1. turn ignition on but not running
2. Use multimeter from black w/brown stripe (+) and green(-)on tach, should say 12v
3. use multimeter on ohms to test resistance of wires a) from tach to 6 pin connector near fuse panel b )from six pin connector to spark unit(only the yellow w/blue stripe wire)
3. If ohms are excessive then replace tach. Didn't give a number, or whether to do it with ignition on or not...
My tach was going from normal to zero and then normal. Did so several times. Ran till I turned it off, Now bike won't start...I got it pinned to three things, tach or cdi, or pulse generator. Anyone know, till I get a chance to check it out?
