Suspension issue
Old Sep 30, 2008 | 05:54 PM
mj_wils1970's Avatar
Default Suspension issue
Can anyone confirm that a bike that constantly bounces (thing pogo) is having an issue with the rebound?
The suspension is stock and the fork oil has just been changed (10W). There is no air pressure in the front fork and the back is set to 1 on both preload and rebound.
Thanks for any input...
Mike
[align=left] [/align]
Old Sep 30, 2008 | 07:48 PM
Hurricane rider's Avatar
Default RE: Suspension issue
I cant say for sure, but here's what I'd do if I were you. find a local guy that has a good reputation doing suspension work, and get yours set up for your weight.
I dont personally even HAVE a stock shock in rear, nor stock springs, mine are some fancy springs, not sure what though, and an Ohlins rear shock. overkill for street, but pretty friggin nice.
Old Sep 30, 2008 | 09:14 PM
michigan_313's Avatar
is it the front or the rear that is bouncing?
if it is the front, could be the springs are shot. if it is the rear, the shock could be adjusted to 2 or 3 to see what happens but if all else fails, it's probably tapped out.
Old Oct 1, 2008 | 07:31 PM
Hi,
I've changed the rebound setting and it does make it better but does not eliminate it completely. Is this shock rebuildable? Is there a shock that will fit off of a late model bike?
Thanks,
Mike
Old Oct 1, 2008 | 07:38 PM
rebuildable? honda manual says no.
late model fitment? no, not directly. later cbrs are either shorter overall or use different mounts (eyelet instead of clevis). there may be one that may fit but you will have to look at pics to be sure of mounting and ask for overall length.
i've seen a couple f1 shocks on ebay. they aren't very expensive.
markybwoi
Apr 11, 2011 11:35 AM
doworktuff
Feb 14, 2011 03:24 PM
StangLou
Sep 1, 2007 08:49 AM
exup547
Sep 14, 2006 08:10 PM
exup547
Sep 14, 2006 04:40 PM
