Sup i got one of these.
Old Sep 26, 2008 | 11:25 AM
HeresJonny's Avatar
Default Sup i got one of these.
Mine is so ****ty haha. last friday I broke down on the highway, it stopped igniting. flooded the carbs with carb cleaner and then it started up. does anyone have a good trick for getting the spark plugs out cuz its so tricky to do for me and they might be seized in.
Old Sep 26, 2008 | 11:40 AM
Hurricane rider's Avatar
Default RE: Sup i got one of these.
18mm deep well thin wall socket, a short extension and pull the radiator off to make access easier. Personally, I can reach the plugs through the frame without pullin anything off the bike, but my hands arent real big either, so I'm good at a lot of stuff. while you're at it, pull the carbs and clean em good. oh yeah, good fuel filter change will also be beneficial to you.
Old Sep 26, 2008 | 11:45 AM
HeresJonny's Avatar
ok yea, this winter my brother and i are gonna possibly do a engine rebuild. so ill freshen up the carbs. also i was told that these have ancient types of plugs that have threads on the end or something, so what plugs would i replace them with if u could let me know. thanks in advance.
Old Sep 27, 2008 | 09:18 AM
tds94probe's Avatar
no theyre not an ancient type of plug, all spark plugs have that threaded end, only difference is that ones used in cars have a cap screwed onto the threads. Go to honda and just ask them for the proper plugs for your bike. I wouldnt use aftermarket, unless youre modding the bike you could go with Denso.
Old Sep 27, 2008 | 10:13 AM
HeresJonny's Avatar
ok thanks a lot
Old Oct 1, 2008 | 07:12 AM
HeresJonny's Avatar
Another question, are the new plugs i am putting in gonna have those caps, if they do should i take them off?
Old Oct 1, 2008 | 08:17 AM
ORIGINAL: HeresJonny
If you want the plug wires to connect on them, yes. its not a hard thing to do though, just simple screw on setup, real easy to put on/take off.
Old Oct 1, 2008 | 11:53 AM
rrasco's Avatar
NGK Spark Plug: DPR8EA-9
I take the socket (I believe with small extenstion too, cant remember ATM), not attached to the drive, I slip the socket over the plug, then attach the drive to the socket. This makes it easier than trying to maneuver the drive and socket into the frame. I then use a fuel hose to slip over the top of the spark plug and pull it out; I think 5/8 is what I use.
[/align][/align]
Old Oct 1, 2008 | 04:17 PM
HeresJonny's Avatar
ORIGINAL: rrasco
[/align][/align]
yea he told me that down here pretty much, i ordered the special 18mm socket
Old Oct 3, 2008 | 11:57 AM
HeresJonny's Avatar
replaced the sparks, didnt do much, sounds like it might b missing, my friend said it might b the timing
