Streetfighter conversion questions
Old Aug 20, 2009 | 06:12 PM
Thaibiker85's Avatar
Default Streetfighter conversion questions
Hey guys I have a 1987 hurricane 600 and I think I am going to convert it into a streetfighter-ish. Meaning I want to install a new digital cluster and new set of headlights. My questions are:
Is it very difficult to convert to digital cluster??
Anyone ever buy stuff from xpostreetfighter.com??
Any advice and/or how to's will be greatly appreciated.
Thanks
Old Aug 20, 2009 | 06:49 PM
markbarber's Avatar
i have an 89 that i changed to a streetfighter(i will post pics later) the best place for stuff is on E-bay, i got the acerbis cyclops headlight for $60, i changed my analog gauges to a digital speedo(kosonorthamerica.com)wasn't hard at all to do the switch, any other questions don't hesitate to ask.
Old Aug 20, 2009 | 07:01 PM
Thanks man, I can't wait to see your fighter. I forgot, but the hurricane has 37cm. front forks right?? i need the right number for the brackets that I want to buy. Wow that's a great site, lots of stuff. Yeah I am thinking of getting dual headlights (horizontal)
thank you very much!!
Old Aug 20, 2009 | 07:14 PM
dopey's Avatar
i wanna go streetfighter to but i have read about people having problems with the air intake once you remove the front fairing i guess the ram air affect that happens decreses performance any info on if this is true or not and if it is how to counteract this woud be great
Old Aug 21, 2009 | 05:11 AM
KongBastard's Avatar
I won't go into what the real cause is (posted elsewhere on the site I think) but the easiest fix is to either cut a couple of inches off of the snorkels that go between the frame holes and the airbox or remove them and plug the frame holes. You won't have any issues after that and no noticible performance decrease.
KongBastard
Old Aug 21, 2009 | 11:28 AM
markbarber's Avatar
what i did with the intakes was take the tank and the cover for the air cleaner off, go to the hardware store and get the tape used on your ducts(it is a shiney silver tape) take a chunk off and cover 3/4 of the hole on the inside of the frame, it is a fit forming tape so press it all around the hole put the snorkels back on make sure they fit nice the reassemble everything, works great and should take1/2hour to do
Old Aug 21, 2009 | 04:52 PM
MetaLord 9's Avatar
Wasn't aware of the snorkel issue & I've got one that's streetfighter bound. Did you guys find that the best thing to do with the oil cooler was mount it under the radiator?
Old Aug 21, 2009 | 09:36 PM
Yeah I've seen alot of hurricane streetfighters with the oil cooler mounted under the radiator or running up and down on one side. I just got my front cowl off and I've just ordered dual 4 inch headlights and digital gauge. I hope I can figure out all the wiring and stuff.
Old Aug 22, 2009 | 06:45 AM
markbarber's Avatar
i left my cooler were it was i cut out the rubber and used clamps to attach it back to the forks(i tried to upload my pics but it didn't work anyone know what i was doing wrong or another method to use?)
Old Aug 27, 2009 | 03:26 AM
constantproject's Avatar
http://www.customfighters.com/index.shtml they have some links that have cool stuff and they all have inks, if i trade my gs750 for an 88 600hurricane it will end up a streetfighter badass...if it goes through
Joecbr
Apr 17, 2026 01:44 PM
AKCBR600
Sep 30, 2013 11:13 AM
adamtonychambers
Sep 3, 2013 12:19 PM
MaxKid84
Mar 17, 2010 02:57 PM
99 CBR F4 Man
Nov 10, 2007 11:10 PM
