Still leaking fork oil after seal replacement!
I replaced the fork oil seals and dust caps because fluid was leaking. I know I did the work correctly and followed the directions in my clymer manual. They were find for about 500 miles and now when I ride and get off the bike, I can see the top point where the forks depressed (dust ring on the tube) and I can see the fluid sliding down.
When I did the repair I did not see any damage on any of the parts as the manual said to check for. I did hit a couple mild pot holes, nothing to worry me at all. What should I do? just replace the oil seals again? The manual said you could use ATF as the fork oil which I did, maybe this is too thin of an oil?
