RR Conversion Bike Coming To Life
I'm still here. I just got mine running after more than a year sitting in the garage on stands. Not because anything was wrong with it, just because I never had time to ride. The carbs needed A LOT of love to get it to fire again. Glad I put in fuel stabilizer this time around.
I have other bikes that sit and fire right up. The CBR's don't like to sit for long. I guess they did that so we ride them more.
It took me years to learn how to do things the right way, at least I feel like I do things the right way...then I also am a perfectionist, which makes it take a long time. This bike turned out really well. It rides as nice as it looks. All the new parts I put in makes it feel like a new bike which is a bonus to how it looks.
you're very welcome! your rr conversion is actually what inspired me to purchase my 1988 f1! i have 2003 rr fairings on the way and will be referencing your posts alot. keep up the good work man! and like you mentioned before the f1 senction of the forum has gotten pretty quiet..
Hey Denny, I just found this thread. Woo-hoo, it sounds every bit as good as it looks! It really came out beautiful. Now we just need a video of you riding it.
My CBR has pretty much been languishing this year. I rather unintentionally started a side business re-dyeing motorcycle leathers for local racers after they saw some I did for myself. A couple of them have talked me into giving track days a shot. So it looks like my HuRRicane is going to be turned into a track bike in the next couple months. Old bike, old rider - should be good for a few laughs.
Thanks so much, I was wondering if still check the threads. I have ridden the bike but no one was around to video me. It runs out really well and is tight as a drum. The Progressive shock is a bit stiff for my old butt, but it feels right. I'm very happy with how it turned out.
If you read this, how did you deal with the high/low beam. I can't get the low beam to come on with the high beam as I think the RR must have had a relay in the circuit.
I need to check, but I think I left the setup so that either lo or hi is on, but not both at once. I had a headlight modulator in at some point and that limited my wiring choices.
Since the wire lead to the hi beam is switched off when the lo beam is on (I think), you could just splice the wire from the hi beam to the lo beam as well. Then you would get lo beam only on the lo switch setting from the original lo beam feed, and hi and lo together from the hi beam feed on the hi switch setting.
That's assuming the hot side of the wiring is switched and not the ground side. Also assuming the switch or relay (I simply don't remember the circuit wiring) can handle the current.
I need to check, but I think I left the setup so that either lo or hi are on, but not both at once. I had a headlight modulator in at some point and that limited my wiring choices.
What happens is the high beam powers the low beam and the low beam powers the high beam so they are both on no matter what position the switch is in.
That's why I was thinking the RR high beam has a relay to power the low beam but switch the feed off when on low beam. I think that would work if I get around to doing it.
