Rim Job
Old Jan 29, 2007 | 12:31 PM
SIRR1's Avatar
Default Rim Job
Ok, here is my first attempt at a polishing a CBR rim.
It's not perfect and pleasekeep thisin mind thatthe rim is 20 years old.
The rim has somecasting flaws and some really deep scratches that I was not able to remove with out digging deep into the aluminum.
I am sure a professional polisherwould be able clean them up, I am not a professional aluminum polisher so please keep this in mind..
So here it is, link
http://s26.photobucket.com/albums/c1...%20Rear%20Rim/
Old Jan 29, 2007 | 12:54 PM
rrasco's Avatar
Default RE: Rim Job
looks good, but did you really have to title it RIM JOB?!?!?! LOLOLOL!!!!
Old Jan 29, 2007 | 03:33 PM
SIRR1's Avatar
Default RE: Rim Job
ORIGINAL: rrasco
I almost titled it "My First Rim Job"
Old Jan 29, 2007 | 08:10 PM
smitty's Avatar
Default RE: Rim Job
Not bad at all for your first RIM JOB. Just wondering how are you going to get
the center of the wheel or are you going to leave it? I'm thinking maybe with a
dremel tool? Did you us airplane cleaner?
-smitty
Old Jan 30, 2007 | 12:13 AM
drakito's Avatar
Default RE: Rim Job
Nice. Do the frame next! lol
Old Jan 30, 2007 | 04:37 AM
bushmasterAR15's Avatar
Default RE: Rim Job
Do you charge for rimjobs, if so how much??
Old Jan 30, 2007 | 11:38 AM
SIRR1's Avatar
Default RE: Rim Job
ORIGINAL: smitty
-smitty
The center of the wheel on the right side will be behind the brake rotor so that will be left alone, I might paint the rotor mounts that run from the hub to the rotor, I still have work to do on the rim.
The left side has the sprocket mount and that has been polished, I did that last month,so I think the center of the rim should be ok, I just need to clean up the sprocket.
I used an automotivetype paintremover, not the type used for home paint stripping. $12.00 a gallon at Lowe's Hardware.
2 applications and the rim was clean.
The one thing no one has noticedis that I ground off the lettering inside of each spoke and the casting fill lugson the reverse side to get the smooth look inside of each spoke.
That by far was the hardest part of the "Rim Job".
My next step will be to go over the rim with 1200 gritwet sand paper on the die grinderand then polishand seal with a clear coat.
Old Jan 30, 2007 | 12:21 PM
telgren's Avatar
Default RE: Rim Job
ORIGINAL: bushmasterAR15
so wrong, just so wrong
Old Jan 30, 2007 | 05:07 PM
Default RE: Rim Job
Ouch!![:@]Nevermind.
Old Jan 30, 2007 | 08:39 PM
Stokersrule's Avatar
Default RE: Rim Job
Looks a lot likethese without the crazy price.
http://www.oncycles.com/the_store.as...&bike=1404
