Request: Carb clean How to
Old Sep 11, 2008 | 02:13 PM
1989cane's Avatar
Default Request: Carb clean How to
Hey guys, I'm new to cbrforum. I have an 89 cbr600f1 aka "the cane." Anyway, I'm pretty sure the carbs need to be cleaned and possibly synced. I was hoping that either someone might know of previous how to for that or that a mechanically minded individual might be willing to make one. Thanks in advance for any help you are willing to provide.
Old Sep 11, 2008 | 02:38 PM
Hurricane rider's Avatar
Default RE: Request: Carb clean How to
I dont know of a how to, but I'll tell you that it is a very good idea to have a dremel with a cutting wheel to slot the heads on some/all screws on the float bowls and diaphragm covers, since they're DAMNED SOFT screws and tend to be rather tight. once out, replace with appropriately sized allen head machine screws.
Old Sep 11, 2008 | 04:38 PM
rrasco's Avatar
I thought someone wrote a tutorial already, but I couldn't find it.
This might help some:
https://cbrforum.com/m_48059/tm.htm
Found a how-to, its not for a cane specifically, but it should help out none the less.
https://cbrforum.com/m_311016/tm.htm
Old Sep 11, 2008 | 08:03 PM
thegreenbandit's Avatar
I was wondering, is there a reason why you can't spray carb cleaner into them, like on a car?
Old Sep 11, 2008 | 08:27 PM
rrasco's Avatar
I don't know of a reason not, just always better to clean them since our bikes are so old, and if newly purchased have more than likely been sitting for some time. Sea foam works good though.
Old Sep 13, 2008 | 11:37 AM
tds94probe's Avatar
if you just spray carb cleaner down them its not going to clean the **** out of the bowls or the jets, on ANY carb'd vehicle its best to remove it and pull the bowls and jets out, thats the only way youre going to get a proper cleaning. TB cars you just take the air intake off and spray away, but carb'd cars, i would still rip er off and strip er. You way also want to check the float height. If its not set correctly, the bike will not be at its full potential at about 25% throttle.
Old Jan 5, 2011 | 11:41 AM
skull rides's Avatar
Unhappy
hello everyone !
needing some info on my current project 1990 cbr 600
i recently had the tank cleaned and carbs
was really excited about getting that done
well brought it home put it all together
then started right up no problems
but i notice it was idling high around 3k
then i let it run so when i started to give it some throttle
it just wants to die so i rechecked everything again its doing the same thing
fuel pump is working well check all vacuum lines
thanks
please help
Old Jan 5, 2011 | 01:35 PM
tds94probe's Avatar
Your bike is not getting enough fuel. Are your mixture screws set properly to 2.5 turns out?
Old Jan 5, 2011 | 01:57 PM
tds94probe !
hi thanks for the info
2.5 turns out im going to do that now
thank you so much
ill let you know how it turns out
Old Jan 5, 2011 | 03:17 PM
question ?
the screws are notch
they have a notch on the screws you cant turn a whole turn cuase the notch on the screw hit the bowl
the two on the out side do not have notches
i turn them in then 2.5 out
going to try it see what happen
thanks
