Replacing Air Filter & spark plugs
I will be replacing the air filter pretty soon on the cane and I have service manual as to the how to. However, is there anything I should be aware of. Do I have to go through the trouble of draining the gas tank in order to do so? I only ask since I'll be installing plugs as well. (I have searched but nothing seemed to go into detail)
Best regards,
Best regards,
Like Billistic said, you don't need to drain the tank to remove it. Just make sure you turn the petcock (fuel selector) from on or res to OFF. A little fuel might come out when you pull the fuel hose off but it shouldn't be a lot. When you remove the fuel line there is also a tank vent hose that you have to disconnect, you don't have to but it's kind of long and vents down by the rear shock.
In aus and new zealand we have a autoshop called super cheap auto, they do some motorcycle parts, oil/filters for offroad modals ex they had a great little motor cycle spark plug tool that was perfect for the job on the cane
As a matter of interest , whice plug is colder/hotter the 8 or 9? mine
had 9s, but only 2 of them? the shop only had 8s , its our winter here around 10 degres and less some days and the bike is running great with the 8s.
