Regulator Ground
Okay, I've got it all bolted on and the battery appears to be charging.
BUT I'VE GOT A NEW PROBLEM!
Now when the bike is idling the multimeter reads 14.5+. When I run it up to 5,000 RPM it reads 18+. Is this normal? Am I going to cook the battery?
It's not working. Is there an adjustment on it, or is it a sealed unit? Sometimes you can adjust the max voltage.
This might help, too, dunno.
http://www.cbrextreme.com/downloads/...%20Diagram.jpg
ORIGINAL: blaster
In my opinion, it's working like it's supposed to.
Keep in mind that while you are riding, the charging system is providing power to operate the bike AND keep the battery charged. Since the lights are always on this requires more power, as opposed to a car where the lights are not always on.( OK, unless you have a newer car with daytime running lights , which still are less watts than the normal nighttime lamps )
The OEM reg./rect. are a known problem on these bikes. Maybe they have a new design for the replacements. I don't know.
The reason I chose aftermarket is because they were much less expensive and I am tired of paying such a high price for OEM parts.
Hope this helps.
