Proper Throttle Cable Routing??
Hi, I have a sticky throttle. It's hard to turn and when you let go, it doesn't spring back to the closed position. I took the carbuerator out with the cables attached and the grip turned really smoothly, so I'm pretty sure I have routed the cables wrong.
Can anyone provide a picture or description on the proper cable routing? The bike is a 1990 cbr600f. Thanks for any help.
Download the manual here and look in the general info section 1. Shows a picture of how it should be.
http://www.cbrextreme.com/downloads/...manual-54.html
i would also disconnect the cables, and spray some WD-40 through them to flush and lubricate. should be a pretty straight shot from the grip, to the right of the steering stem, right of the radiator cap, under the airbox, to the carbs.
