problems
Old Jan 1, 2009 | 08:11 PM
CBR f1 stunter's Avatar
Default problems
Im new to the forum, I have an 88 600f.all ferrings taken off except front,two 5 mph drops on it.idles up and down, when i shake it it turns off, lost alot of power in one night when it rained sounds alot different.when i try to accelerate it hesitates.i have no clue it was perfect when i bought it.it has 18k miles on it.when i pull in the clutch it dies unless i give it gas.
Old Jan 1, 2009 | 09:16 PM
thrasher572's Avatar
Default RE: problems
Slow down son. Lets try describing one problem at a time. If you have access to a digital camera post up some pics.
How old is the battery?
Have you tried cleaning the carbs?
How does the air filter look?
What damage did you do in the 5mph tip overs?
When you move the choke lever is there anything happening down at the carbs?
Have you tried adjusting the idle?
Old Jan 2, 2009 | 01:48 PM
pretty new battery.on the tip overs just ferrings were damaged.the previous owner pushed the choke to hard and broke it.just cleaned the air filter and sprayed carb cleaner in carbs.i have alot of trouble starting it at night with no choke and lose alot of battery trying to start it.my idle *** doesnt seem to work either its wierd.
Old Jan 2, 2009 | 02:31 PM
Hurricane rider's Avatar
that suggests you really need to clean your carbs, and the choke lever is an issue I have with mine too.
Old Jan 3, 2009 | 04:55 PM
Clean the carbs, repair the choke lever. Let us know the result
Old Jan 3, 2009 | 05:32 PM
how do i fix the choke lever
Old Jan 3, 2009 | 07:37 PM
you've gotta take the left control cluster off and replace it. there is no other "fix" that I know of for it.
Old Jan 3, 2009 | 10:16 PM
and as for the shaking it and dying,and the idleing up and down?
Old Jan 3, 2009 | 10:47 PM
clean your carbs, it'll fix that. I just went through this with another person who had a ZX7R that was doing EXACTLY the same thing when he rocked it side to side. after he cleaned the carbs with my online aid walking him through step by step, his bike ran perfect.
Old Jan 4, 2009 | 04:00 PM
tripicana's Avatar
x4 on check your carbs.
i have a control switch assembly with the choke lever and cableif you need one.
