Pro Evo Shift Kit
Old Sep 3, 2007 | 10:00 PM
OLDbutFAST's Avatar
Default Pro Evo Shift Kit
I was just looking atrandom parts for my bike andIfound aFactory Pro Evo Shift Star Kit. Has anyone had any experiences with shift kits. are they worth it?
Old Sep 3, 2007 | 10:06 PM
honda502's Avatar
Default RE: Pro Evo Shift Kit
That is so wierd. I was just looking at the factory pro website and reading about false neutrals on the vfrworld forum. I am curious about this myself, for the VFR. I hit a false neutral every once in a while, and was wondering if this would fix it.
Old Sep 4, 2007 | 10:40 AM
rrasco's Avatar
False Nuetral? like it popping into N when it really shouldnt be? I have had that a time or two.
Old Sep 4, 2007 | 11:20 AM
OLDbutFAST's Avatar
Thats the same thing I was thinking about when I read about it. but I havn't found much info on it yet.
Old Sep 4, 2007 | 09:28 PM
honda502's Avatar
On my VFR, after riding for a couple hours and getting comfortable, sometimes between 5th and 6th I will not pull up far enough on the lever and it will ratchet and rev up like it is in neutral, then pop back into 5th gear. Scary stuff, sounds like hell and lurches the bike. Supposedly that kit makes the shifts feel more solid and precise. But you have to get the whole thing, not just the spring and lever. The key is the star wheel.
Old Sep 4, 2007 | 10:35 PM
OLDbutFAST's Avatar
the kit I was looking at was the one with the star wheel
Old Sep 6, 2007 | 12:38 AM
rrasco's Avatar
ORIGINAL: Scythe525
I've had this happen too, only on my '90 F1. It sounds like some piece fell off inside and is griding the gear and then it pops back down and lurches like you said. It freaks me out so i pull the clutch in but then it goes away and doesn't happen for a long time. dunno what causes it..
ORIGINAL: honda502
mine makes that sound more often when i shift from 2nd to 1st going over nuetral.
Old Sep 17, 2007 | 09:31 AM
daytonatrbo's Avatar
ORIGINAL: rrasco
Mine did that when i was driving it out of the driveway i bought it in.
If those kits do what they claim, i think the $200+ price is fair. Im no racer, but quick, solid shifts are never a bad thing.
Old Sep 17, 2007 | 04:07 PM
honda502's Avatar
Check your drive chain tension. Mine was too tight, when I loosened it, the problem got better on the Viffer. Might also move the shifter lever down one tooth too.
Old Sep 17, 2007 | 04:25 PM
if anything my chain is too loose. its got plenty of slack.
