Plastics similarities for the 87-90's models
Thanks Thrasher! So, the 90 and up plastic won't fit or will it fit with some body fudging? By any chance do you know if the 1000 plastics are interchangeable? seems like there are plenty of those floating around. My 600 needs all the lowers and probably the rears as well since the tabs are broke off. Any way to fix those push on tabs?
i found these will work.
if you have a U pull it type salvage yard near by, look for second generation volkswagen golfs or jettas. it holds the horn button to the steering wheel. you need to look for a two spoke wheel, not the four spoke.
ill be hitting up the junkyards later this week, ill try and snag a few.
madkawa
06-05-2009 05:34 AM
