Petcock
Old Jan 24, 2007 | 12:18 PM
zeppelin2112's Avatar
Default Petcock
Will most CBR petcocks work on the 1990 CBRf, or only the compatible model years, or what.
And if so, anybody feel the need to get rid of one for really cheap?
Old Jan 24, 2007 | 12:53 PM
rrasco's Avatar
Default RE: Petcock
i dont know if they will fit other years, they are around $35 new from Honda. mine leaked horrifically in the 'OFF' position only.
Old Jan 24, 2007 | 01:27 PM
Default RE: Petcock
Off, on, reserve, it doesnt discriminate. Im strapped for cash right now, and wont get paid till sunday. Hurry up and wait, it is!
Old Jan 24, 2007 | 03:23 PM
michigan_313's Avatar
Default RE: Petcock
i believe petcocks are interchangeable between f1-f3 (pretty much the same tank), after that they started going to in-tank fuel pumps on the f4 and later.
you may want to check on ron ayers website in the microfiche but i am pretty sure 87-98 will work.
Old Jan 24, 2007 | 06:31 PM
telgren's Avatar
Default RE: Petcock
I picked one up for $20 a few months back that was in pretty much new condition. Just whatever you do dont try to drill the rivets out like I did [&o]
Old Jan 24, 2007 | 06:39 PM
Default RE: Petcock
great advice XD I was going to attempt that in about an hour, haha
what went wrong, if you dont mind my asking?
Old Jan 24, 2007 | 07:09 PM
telgren's Avatar
Default RE: Petcock
Well I was looking at the bike yesterday before I started it up after a late season oil change, and there it was: a single drop of fuel. Taken back I immediately discovered my petcock was leaking, pulled the tank off, proceeded to tip it over spilling about 1/2 gal of gas in the process. I figured the petcock would just be an o-ring problem, but I was taken back when I realized that the petcock doesnt even come apart. The damn thing is riveted together, so I had to take it out to our shop, drill out the rivets, pop the cover off only to look at the main gasket that determines where the fuel is going. After 18 years I guess it finally wore out. The gasket had all kinds of grooves in it from being turned on and off, the lines leading to it where full of junk, and rust in the line leading from the tank. Needless to say I was kinda disappointed because this will more than likely end my season a week early.
What I did try to do was to clean it all up, flip the gasket around, drill all the way through the rivet holes, and pull everything back together with a couple of self tapping screws. No luck, the gasket was way too messed up to hold fuel without leaking a small drop now and then again. So if anyone ever wants to take apart their petcock, its possible just make sure to have the small gasket with the four holes on it beforehand. Also if someone was to do it right I would recommend having the oring that goes around the selection dial.
1992 gsx600f
Mar 10, 2011 12:57 PM
jestr
Feb 15, 2009 11:06 PM
tazshido
Feb 25, 2008 01:56 PM
cbrboyze
Nov 9, 2007 07:54 AM
