once again another problem
Old Jul 1, 2010 | 02:30 PM
ConcealedDeath's Avatar
Default once again another problem
Well I got the 89 600 f1 running today.
My problem now is that the 4th exhaust doesn't get hot. I checked the spark plug and it has a nice strong blue spark.
Any suggestions???
Old Jul 1, 2010 | 07:41 PM
I guess it is the third and fourth exhausts not getting hot.
Old Jul 1, 2010 | 08:20 PM
Procrastinator's Avatar
Check your compression!
What is 4 vs the others?
Old Jul 1, 2010 | 08:21 PM
Could be 3 and 4 wires are reversed.
Switch them, start it, and see if 3 and 4 pipes get warm.
Old Jul 2, 2010 | 06:29 PM
reversing the wires didn't change anything. I should check the compression though. Hopefully they're all good.
Old Jul 2, 2010 | 06:54 PM
JesseAwesome's Avatar
Are those particular cylinders getting spark? Did you check the plugs?
Old Jul 3, 2010 | 12:13 PM
Just read you checked the spark plug, so it is sparking... if it' sparking then it's gotta be fuel delivery.
Old Jul 4, 2010 | 11:57 AM
morbidphil0622's Avatar
Do the cylinders fire correctly when you bring the rpm's higher for a period of time? I had the same problem when I got my hurricane put back together and it ended up curing itself when I got the main jets to kick in..
Last edited by morbidphil0622; Jul 4, 2010 at 11:59 AM. Reason: Just seemed like the thing to do at the time.
Old Jul 5, 2010 | 02:36 PM
So if it is a fuel problem then it has to be that my carbs aren't clean or something wrong with the jets?
Could it be a compression problem? I was going to go buy a compression gauge but if that can't be the case then I won't.
Old Jul 5, 2010 | 10:01 PM
I would try cleaning the carbs and jets really good, It is fairly simple to do..
