Is it normal for idle to 'flutter'?
I've gotten alot of the kinks worked out on the bike so far, but cannot seem to get around this one. when I set my idle to 1200 rpm it will flutter from 1000 to 1500 or so. I'm sure a good carb sync would do wonders, but I was just wondering if this is normal with an older bike.
Next projects include: checking the cct (I'm hearing the ticking that is talked about in the forum), and checking my thermosensor. Hopefully I'm not in too deep on these ones - I am certainly no mechanic - but I really enjoy doing my own work on the bike.
600RR tail section swap
digital guages
Plastic weld lowers and mid panels
Repaint (Not sure of scheme yet) - but probably to match my icon eternal saint helmet.
My plans so far:
- new tire front and rear (ordered)
- remove what's left of the stock plastics (and ebay those suckers lol)
- '03-'04 600RR tail swap (got the seat and little side panels ordered already)
- this belly pan (ordered)
- this headlight/fairing:
- paint exhaust with Techline Black Satin 2000 degree header paint
- repaint engine black
- remove stock gauges from fairing mounted panel and make new fork mounted panel for them, perhaps do some funky new turn signal indicators
- paint or powdercoat wheels and frame black
- paint tank and plastics some wild candy, pearl, or chameleon colour
- chop the passenger pegs and mounts (using the solo rear seat cowl), hack off the unnecessary parts of the subframe and fab new mounts for the tail and exhaust
- new chain and sprockets
And since I'll have the engine out to do the paint, I'll clean the carbs and install a new CCT, and do whatever else needs done. That should keep me busy until spring I'll be starting a project log over on customfighters.com when I get going.
I like the Rogue fairing. I think you will have to get different gauges ( http://trailtech.net/vapor.html ) as the stock ones are a single assembly not individual gauges.
Post pics along the way.
KongBastard
KongBastard
