New clutch problem?
New clutch problem?
I have just installed a new set of EBC fiber plates and springs in my 88. My issue is when I engage the clutch one would expect it to engage early but now it seems to just barely engage at all. I adjusted the cable out a lot to finally make it engage but this seems wrong. What have or haven't I done to my clutch to cause this?
RE: New clutch problem?
you adjust the cable at the side of the case so it has a little resistance, then back it off just slightly so that the clutch is fully engaged, then you adjust your lever so it has about 1/4 inch of play in it. bada boom done. If you want a little stiffness in your clutch, you can put 1 small washer under each clutch spring but only 1. Look on factorypro.com for the exact thickness they used.
I replaced the springs (which were thicker when compared to the stock), when I replaced the fiber plates I had them stacked in the order that they came off (first and last plate are different then the middle four). As I replaced a plate I put its counter part in the clutch basket so I don't think I was missing a plate.
