need help with projector headlight
tested stock wiring the other day and found my ground/hi/lo. they both worked with the key on. i also tested the headlight i got with a 9v battery and it lit up (dim but it was just to test it). after i wired it into the stock harness it didnt work.
i then tested the light again and it worked. and then tested the harness again and it didnt show power coming from the hi or lo.
now im kind of at a stand still with it.
im about to go rip the bike apart to change my plugs, ill take pictures if thatll help
the headlight is a single beam projector. h3 i believe.
could i have blown a fuse or something?
is the light compatible with the bike?
How do you have it wired up?
If it's a single-beam with H3 bulb, you should connect only the low-beam power-line to it. The high-beam should be disconnected.
If you had a bi-xenon projector, then the high-beam line would connect to the solenoid that flips up the shield.
Look up the wiring-diagram and find the fuses for low & high beam circuit. You may have blown both of them.
