Main jet size and needle position stage 2 jet kit?
Old Nov 7, 2009 | 04:08 AM
w00dzy's Avatar
Originally Posted by cba4
One thing I did notice was instead of the 2 holes drilled in the slide bottom there is only one. Is this an old configuration or something other than Dynojet. The hole is between where the dynojet spec sheet shows to drill.
I suppose this would change the pressure needed to raise the slide (slightly).
I guess my next step is to try some different jetting configs
I found the same hole in my slides. I have fitted DJ kit with 124 mains and am running a full straight through system with minie k&n style individual filters.
My needle is set to the 4th from the top. It appeared to be running rich in the low revs.. Could smell the fuel...
When I drilled the slides I enlarged the existing hole and drilled another one.. I think this is causing the needles to lift to soon..
Any ideas? Sugestions?
Old Nov 7, 2009 | 10:49 AM
tds94probe's Avatar
why the heck did you drill 2 holes? the handout even says slides may not be exactley as shown. yea thats definetly causing them to lift too soon, you either need to find some way to close that hole up, or find some new slides.
Old Nov 7, 2009 | 12:33 PM
w00dzy's Avatar
I know, it was a dumb thing to do.. thought that it should be the same as the handout picture.. Luckily I have a spare set.. will let you know how it goes.. I think im going to try them without drilling it at all.. will post pics up of filters soon you will love em!
Old Nov 7, 2009 | 03:44 PM
cbr89600's Avatar
I am in the same boat as you - sort of - I don't know what kit is in my bike, but the PO installed a jet kit and K & N with drilled airbox lid, drilled the sliders.. the whole works. I can smell that it is running too rich in my case, too and too much soot on the tailpipe.. all the telltale signs including stumbling at lower RPM especially after idling. I am thinking of trying to go back as much to stock as possible - can the sliders be swapped out pretty easily? How much do you think it will cost at a shop to have the jet kit taken out and sliders replaced? Or can a jet kit be tuned to be more of a lean, normal setup closer to stock?
Old Nov 7, 2009 | 07:18 PM
w00dzy's Avatar
You will need to find out if its running rich on the pilot or main jet.. Have you tried adjusting the pilot screw? Check out my project.. I'm going to do some test runs tomorrow to see what needs changing next.. Probably need to re drill the slides. It is fairly easy to swap them over. It took me and a mate about 30 mins. Let you know how it goes tomorrow...
Old Nov 7, 2009 | 09:54 PM
tds94probe's Avatar
you need to properly tune the jet kit, they are not just simply drop in the largest main jet, pic a needle clip position and go. NO TWO bikes in different areas will have the same setup.
as far as your stumbling goes, adjust your float height, that controls low rpms along with your pilot.
Old Nov 8, 2009 | 07:40 AM
lloydiecbr's Avatar
[QUOTE=cba4;641218]Here goes nothing.
This is what was referred to in the dynojet specs as insert DIF22
[IMG]local://upfiles/24609/CE1E964DD0E64F99B5043504BFBCFF1D.jpg[/IMG]
i would like a copy of the template but i cant see it . would any one be able to help
Old Nov 8, 2009 | 07:49 AM
w00dzy's Avatar
What template mate? I cant see it either..
Old Nov 9, 2009 | 08:12 AM
b1m3x8's Avatar
He didn't post the picture right. Upload the picture to a photo sharing website then post it. (Photo bucket)
Old Nov 10, 2009 | 07:45 AM
w00dzy's Avatar
Ok my bike is now running like a rocket.. throttle response isnt 100% though.. Installed the dj needles one above stock setting, mixture screws all 2 1/2 turns out from fully in, individual air filters and 124 mains. I have not yet drilled my slides... any recommendations on how much to drill.. got 2 drill bits supplied in the kit.. cheers
