Ignition advancing
It is an easy install. Remove the left fairing. Remove the left starter cover. Unbolt the pulse generator and replace it with the new one. Just make sure all the starter gears are in place before you bolt the cover back on because one or two may fall out after the cover is removed. Just a tip, an impact gun makes a world of a difference removing the pulse generator bolt becausepulse generator ison the end of the crankshaft. Remember a new gasket too.
Is a 4 degree sufficient? Or should I do with a 6 degree because I plan on putting a slip on pipe on with a k&n filter. And rejetting it as well. Do you really notice a difference with a yosi header? Also where did you find that header I can't seem to find any headers anywhere.
Hindra
07-10-2006 01:47 AM
