Ignition Advancers
Has anyone used an ignition advancer for the Hurricane, or any other CBR? CBRZONE.com has them here. My question is...should I get the +6 or the +4? Right now I have a K&N air filter, full D&D exhaust, and a stage two jet kit. Pretty much I want the most power that I can get while still running smooth. Any help would be greatly appreciated.
Just make sure you invest in dyno time to get your fuel correct. Unfortunately the part will run you $60 but set-up will be closer to $300-$400 to get it properly fueled.
i had the 4 degree and i liked it except at the track, but it was quick in stop and go.. i put it in my F2 when i had the 600 in it, i had a yoshi RS-3, K&N, and a jet kit.. i would go with a 4 degree and some new sprockets! hope this helps..
i dont know how to explain it other than it zipped through the gears really fast and i couldnt wind them out in the rpm range. it climbed really fast and i was in 5th at the line and everyone else was in 3rd. i was losing time by shifting too much.
it improves take off and top speed over a long distance just not good for strictly the 1/4 mile... does that make any sense?????
well i shift at redline or a little higher... it was revving through the gears fast but to shift more gears were cutting my time down. i had time to shift but it was fast through the gears when the throttle was being held open. unless you are going to run mostly at the track then i wouldnt get one, but if you are going to be on the streets,twisties or highway then i would get one. but yeah it is a pretty noticable difference.
i know it sounds wierd and i know that i am just not explaining it right but i am trying....
im still not getting the concept of what is exactly bad about it at the track it goes through the gears fast i got that but im trying to find the problem. if it redlines in first without the advancer it it will only hit lets say 50mph @12500, with the advancer it would still be 50mph at 12500 but would get there alot faster and so on and so forth with all the other gears. im trying to place exactly where that is not disirable in the 1/4 of all things that would bring you to your top speed much faster. or does it bring down the top speed of any said gear? i dont see how that would happen though.
ok. i dont mean to press the issue but i plan to be an all around rider with twisties and some weekends down the drag strip. how many times did you run it with it in, would you be able to improve on your shift to use it to your advantage? or is it just not possible? how much did it do for the low end?
