How much oil
RE: How much oil
if yours is like my F3, you have to remove the Left side fairings to get to the oil filter and drain plug. on the bottom of the crankcase, look for a odd colored (maby 14mm bolt). thats the drain plug. it will be a different color from the rest of the bolts.
as far as oil quanitity, i think the book reccomends 3.7 quarts with a filter change. it will be less if only changing out the oil and not the filter.
hope this helps.
dave
hope this helps.
dave
