Hottt!!!
Old Apr 18, 2009 | 06:29 PM
hypeshipe's Avatar
Default Hottt!!!
MY bike gets so hot around my knees when riding. My temp gauge stays fine but my knees get real hot. Anyone else experience this?
Old Apr 18, 2009 | 06:49 PM
Billistic's Avatar
Yes. Seems normal to me.
Old Apr 18, 2009 | 07:06 PM
hypeshipe's Avatar
OK, at least im not alone. On another note, I had a new oil leak spring up today. Its coming from a round rubber peice under the carbs on the block. Not sure what it is
Old Apr 19, 2009 | 12:05 PM
tripicana's Avatar
your knees get hot because the radiator exhaust is right in front of them. my ***** get hot because the voltage regulator is right underneath the seat.
not sure what you're describing on the oil leak. is it on the cylinder or transmission part of the motor?
Old Apr 19, 2009 | 04:34 PM
hypeshipe's Avatar
tranny
Old Apr 21, 2009 | 11:23 PM
Billistic's Avatar
You should have spent the extra 5 bucks and got the " ball heat shield " that comes as an accessory with a new R/R. It's Sweet!
Old Apr 22, 2009 | 01:39 AM
tripicana's Avatar
i might have to look into building a heat sheild...
any word on the leak, lots of oil, or just a seep? left or right side of top of trans? rubber plug with wires, clutch shaft seal, are there vents on top the of the trans?
