I had something like this with an f2. My aluminium chain tensioners were seized on to rear axle. Took out all rear swing arm with wheel in. In the end a boat load of perseverance, penetrating oil, heat gun and hammering with a copper faced mallet overcame the corrosion. Heated the chain tensioner after wd40 until it was smoking then firmly tapped on it. I had to just work at it like this repeatedly and eventually got some movement.
Just try stuff. You'll do it. |
Originally Posted by dodger79
(Post 1306721)
Just try stuff. You'll do it. That's nuts...were you able to salvage the swing arm or was it destroyed by the end of the process? I don't know if I should just start tearing down the rear swingarm of the bike and eBaying a new swing arm, chain tensioners, etc and just rebuild the rear? I don't know what foot to put in front of the next. It doesn't seem like there are many options for acquiring new parts or aftermarket equivalents. Thoughts on what I should do? |
Yes you can replace the swing arm, but yours is likely repairable.
You'll want to download the manual to insure you take things apart properly and get them back together. Take pictures as you go also. If you got the chain loose and can tension it properly and decide to ride it like it is make sure you get both sides of the axel adjusted the same distance. Consider that the crack portion of the swing arm could break loose and cause the axel to move which could be dangerous. I wouldn't run it like that if it were mine. |
swingarms are pretty cheap from junkyards and online like ebay, etc.......
Originally Posted by dennisgb
(Post 1306724)
You'll want to download the manual to insure you take things apart properly and get them back together. Take pictures as you go also. If you got the chain loose and can tension it properly and decide to ride it like it is make sure you get both sides of the axel adjusted the same distance. Consider that the crack portion of the swing arm could break loose and cause the axel to move which could be dangerous. I wouldn't run it like that if it were mine. I do not plan on riding the bike in its current condition. The reason we started looking in the first place was because I felt the rear end shift ever-so-slightly on me when I had to brake hard in the rear... its not a good choice. "Play stupid games, win stupid prizes." :( |
not to pour salt on the wound but your axle bolt looks extremely knackered too. The threads wallow out nearest the tensioners suggesting that the bolt either stretched or was overtorqued and had the threads shear off
Originally Posted by Zachy72
(Post 1306870)
I am thinking of scraping the bike at this point. |
Have you got a picture of the bike that you could post? I'm just wondering what condition it's in that you are thinking of scrapping for what seems like a simple repair (other than hunting down the parts, of course)
Originally Posted by heresolong
(Post 1306888)
