Headlight out
Headlight out
So all of a sudden last night when I got on my Hurricane to ride home in the dark, my headlight wouldn't turn on. It starts fine and I have turn signals, break and instrument lights, but no headlight and no hi beam indicator when the switch is flipped either.
I first checked the fuses, they all looked fine, then I checked the bulb, it looked fine, replaced it with a new bulb to no avail, and even checked the wiring where the bulb plugs in. I was using a friends volt-meter and it's getting juice, but I wasn't paying attention to how much and from what wires. I ended up having to get a ride home and I'm go get it a drive it back home in the day.
I'm looking at the service manual and I guess the next step is to actually measure the voltages and check ground. It seems odd that the high beam indicator doesn't go on either though.
Has anyone else had something like this happen? I did a quick forum search and found some related stuff, but nothing specific.
Thanks for the advice, I didn't have time to get back to it last weekend, but when I got home form work last night I just tried mashing the starter switch a few times without the key in, then put in the key and hey, whaddaya know? the light works again. The switch must have just gotten stuck.
Thanks again CBRForum!
If it's like my F4i you may want to pop open the cover around your start switch to be sure you're not developing a loose connection. I lost my headlamps awhile back too. First I noticed a delay in the high beams coming on, then occasionally, they wouldn't come on at all until I tried the switch a couple more times. Then one night I started up the bike to head home from the theatre and I had NO lights. High beam or day running
Checked the fuses first (they were fine) and the voltage went right to the lamps, bulbs were good too..
Turns out the wire had come completely disconnected inside the cover. It was dangling in there waving at me...so I had the little bugger soldered
All good now!
All good now!
this happened to mine which was all. even my turn signals stopped work and no lights on the dash came up when you turned any of the lights on. Now everything is working bar the dipped beam, full beam work but cant drive round with full beam on.
i dont know whats wrong, maybe dipped beam bull has blown?
papa wheelie
07-20-2011 11:16 AM
Davidth93
07-16-2009 12:22 AM
cyber00677
08-03-2007 03:57 PM
