Handlebar Risers?
Old Nov 9, 2007 | 08:45 AM
blaster's Avatar
Default Handlebar Risers?
Does anyone make handlebar risers for the 1990 CBR 600? The ones I've found seem to start from 91 and go forward.
Thanks,
Barry
Old Nov 9, 2007 | 11:31 AM
michigan_313's Avatar
Default RE: Handlebar Risers?
that's a tough one. i would venture to say no because risers for such a small diameter fork are a specialty item and not a popular one at that. you could try to ask the manufacturer to make you a set, but i would think it would cost alot. there may be one manufacturer out there who makes/made them but you would have to ask around and dig deep, might get lucky and find leftover stock if they were ever made at all.
Old Nov 9, 2007 | 12:14 PM
blaster's Avatar
I did find these ones:
http://www.1tail.com/sa/p/Honda_CBR_...bar_Risers.htm
But it looks like they just put you up 3/4". I'd really like to find something that went up and back a little. Maybe I'm just getting old, but riding this kills the back of my neck if I ride for 40 miles or more. Of course, I'm used to riding a Geezer Glide so this is quite a switch.
Old Nov 9, 2007 | 12:33 PM
maybe it's time to trade up to a hornet 599. more up to date and a lot more upright.
Old Mar 15, 2008 | 10:44 PM
Detroit Cane's Avatar
how high you tryin to go, try to use some of those screw in risers. you have to do a little drill work though.
Old Mar 17, 2008 | 08:44 AM
nickmac120's Avatar
I found risers that may work. just add a set of bars and your set. I am interested in doing the same mods to my 1990 600f.Will I need long cables and housing with a low rise bar?
http://www.busters-accessories.co.uk/products.asp?id=77
What diameter are the fork tubes? 37mm?
Old Mar 17, 2008 | 12:44 PM
they are 39mm.
Old Mar 17, 2008 | 09:26 PM
nickmac120's Avatar
I found it on the net earlier today 37mm
and another cbrfans forum (87-90 canes have 37mm fork tubes.)
I can't argue 3 vs 1, 37mm it is!!!
Thanks
Old Mar 17, 2008 | 11:24 PM
my bad...
Old May 30, 2013 | 10:30 PM
coolerthanelvis's Avatar
Sorry to dig up such an old thread but this looked the most relevant.
I usually hang out over in the Hurricane 1000F section and one of the ways to bring the handlebars up is to use the risers from an early '90s VFR750. I got my years mixed up and ended up buying a set of bars from an '86 VFR750. Imagine my surprise when I found that they were too small, being 37mm and all. Of course the seller won't take them back so I thought I'd offer them up here. They look like they're MUCH higher and farther back than the stock bars. If anyone is interested, shoot me a PM. Thanks!
