-   CBR 600F (https://cbrforum.com/forum/cbr-600f-15/)
-   -   Was fun while it lasted 😢 (https://cbrforum.com/forum/cbr-600f-15/fun-while-lasted-164303/)
dannoxyz 05-10-2024 07:14 PM
Just leaving upside down for 60-min should be fine to drain oil from top-end. Be sure to check oil-level in crankcase after righting and adjust as necessary.
Bill1987600f 05-11-2024 01:23 AM
Ok so turn upside down leave it for the day then turn right way up , check the oil turn give a couple cranks , then drain oil
dannoxyz 05-11-2024 11:47 AM
Sounds good. :)
Bill1987600f 05-13-2024 05:01 AM
Just a quick one I got a new battery in bike but it’s now going to be sitting a few weeks will it be dead by the time I need it or ??
dannoxyz 05-13-2024 10:05 AM
Is it fully charged? If so, it’ll be fine. Best to connect tender chargee.
Bill1987600f 05-13-2024 10:15 AM
Brand new battery, also when I flip this engine should the piston position be bottom dead centre
dannoxyz 05-13-2024 07:15 PM
Not possible for all pistons to be TDC or BDC. Shouldn't matter, you'll just want to drain everything above piston. Some pistons will be up, some down.
Bill1987600f 05-14-2024 02:17 AM
Ok so I still got to strip my bike so I got a bout a week maybe I flip it then crank, flip it again then crank just while it’s sitting there over the next week or so then drain defore I put it in or drain it once it’s in
Bill1987600f 05-29-2024 03:21 PM
Okay so engine is hanging upside down I made a video explaining what I’ve done if it’s correct ???
dannoxyz 05-29-2024 07:34 PM
Yup, looks good! Drain bottom and refill and should be ready to install! Good job! :)
