Fuel leak at T fitting on carb
Old Jul 6, 2008 | 02:44 PM
Ty_Deschaine's Avatar
Default Fuel leak at T fitting on carb
So i bought a 88 cbr 600F from a guy at work for $200. I got it home and have been tearing it apart and rebuilding it. I rebuilt the Carbs and when reinstalling it i connected a fuel line to a funnel and filled with gas (temporary test to see if it will start up. Bypassing the fuel pump. Fuel pump regualtor is out) After pouring some fuel into the line i spotted a large leak from what seems to be coming from the T fitting that the fuel line connects to. I looked at the fitting and it doesnt seem to be damaged. Has anyone else had this problem and what is the easiest fix?
Thanks guys.
Tyler
Old Jul 6, 2008 | 03:19 PM
Gogar's Avatar
Default RE: Fuel leak at T fitting on carb
There's supposed to be a little rubber o-ring on each end of the t-fitting; make sure you didn't lose one or both of them when cleaning. If you did, you can probably grab some at a good hardware store; find any parts catalog online and you should be able to find the exact size in mm.
If it's not that, I'd make sure your fuel line is the right size as well, and isn't too big I.D. for the fitting as well. Good luck!
3mbc
Aug 5, 2017 04:42 PM
cc rider
Mar 30, 2013 07:59 PM
F4Mike
Nov 22, 2010 09:06 PM
lanceam24
F2 Tech
Apr 16, 2010 06:23 PM
tvoburner
Jul 2, 2009 12:47 PM
