Fuel Economy / Consumption
There was no space for me to try to bump start it: I stopped going uphill and cars were flying by me at 60mph. I was stuck between the freeway and the on ramp (behind the cement separator) where vehicles accelerate go get on the main lanes.
Then again, bump staring it wouldn't have worked either because that's what I had to do once I filled her up. Took 4 tries with someone pushing me from behind before she fired up. I presume that's because the carbs and fuel pump were completely starved of fuel and it took some juice and a few tries before everything got fed again. Probably didn't have enough left to even ignite the spark plugs after I was done trying (prior to relizing I ran out of fuel).
As I said, lesson learned. I'll be laughing about it in a while but it wasn't amusing then and there.
I've been getting around 28-30 mpg on my bike since I bought it last year. I recently pulled the carbs off to clean and check them over. Nothing was dirty or out of spec, but when I put it back together, I noticed that the little brass tubes near the air intakes on my carbs were all uncovered. I remembered reading this thread and realized that I was having a lot of similar problems, i.e. needing to run choke for a long time, sluggish performance, etc. I ended up supergluing some toothpicks into the holes, and WOW! The bike sounds brand new, it's actually holding a steady idle now, and I'm getting near 50 mpg. If it's warm outside, I don't even need to use the choke to start it up now! It's easily been the most significant improvement to the bike I've made. I'm surprised that these tubes and their effect aren't mentioned in either the Honda manual or the Haynes manual I have, since it seems like they're pretty important.
I did the same as mrfisher and saw a noticeable improvement but it also coincided with many other things I did at the same time. Therefore, I cannot say that blocking those holes was the single factor that made my bike run so much better. However, it seems that doing so has yielded amazing results for all those who have done it so far.
ORIGINAL: rrasco
/\/\ You have a pic of those tubes? Something I want to look into.
