front radiator mounting problems
Old Sep 25, 2009 | 11:05 AM
stunt it f1's Avatar
Default front radiator mounting problems
i have an 88 cane completely stunted out except the front small radiator(not the main large one) and the front bracket holding on my tacks.i want to clear all of it out to where its just forks.i need help finding a place to mount the small radiator bacause it is bolted on the metal bracket.any suggestions???
Old Sep 25, 2009 | 12:50 PM
Gogar's Avatar
It's not a radiator, it's an oil cooler.
You could pretty much put it wherever you want, as long as some air hits it and it's not too close to the engine.
Old Sep 25, 2009 | 07:51 PM
KongBastard's Avatar
I have seen them mounted on the right downtube, right underneath (just above the exhaust pipes) the radiator and I have mine mounted at the bottom of the radiator (in front of it).
It is tight for clearance between the fender and oil cooler where I have it so I am watching to see if I have any contact. Been riding it like this for 2 weeks and no problem so far.
KongBastard
Old Sep 27, 2009 | 10:51 PM
if i take my tacks off will the bike have any computer problems will it run any different
Old Sep 27, 2009 | 11:31 PM
Do you mean your gauges?
If so, I don't think any of the wiring is required to be connected in order for the bike to run correctly.
KongBastard
Old Sep 28, 2009 | 08:32 AM
cba4's Avatar
Did you make a bracket for the oil cooler? How did you run the lines?
Old Sep 28, 2009 | 11:11 AM
i have not yet found a place to bolt on my oil cooler.im thinking about mounting it just below my radiator but i dont where to begin.and yes my gage cluster.and how can i put all my wireing and fuses tucked under my seat??
Old Sep 28, 2009 | 05:46 PM
xjoewhitex's Avatar
Theres really no computer its a old carbed bike so no it wont affect anything, ive done it.. And as for the oil cooler I haven't found a solution either to it besides maybe flipping it over and mounting it to the bottom radiator bolts w/ custom bracket.
slipnslide
Sep 20, 2012 02:03 PM
shane_ya_dig
Jan 19, 2011 10:52 AM
jesoulor
Mar 28, 2009 08:01 PM
thebigblue92
Jul 3, 2008 10:19 AM
FreshTracks
Nov 28, 2007 08:56 AM
