Fork oil weight...
RE: Fork oil weight...
Iuse Bel-Ray 15wt with 8psi in each fork.
This is working very well for me!
(not to harsh and no bottoming out)
Fork oil rating works this way.
Lighter weight fork oil speeds up the action of the fork, while heaver weight fork oil slows down the compression and rebound of the fork action, you will tend to bottom out your forks using a lighter weight fork oil because of the quicker action or responce.
ATF is a 15 weight oil and works very well in street motorcycle forks!
The only draw back with ATF is it does not have an antifoaming additive Like a Bel-Ray type fork oil andATF will foam under harsh conditions like Motocross or hard trailriding.
Amzoil ATF or GM Red ATFshould be ok for street use, but if you find the front end getting hard and unresponsive just bleed off the air pressure in each fork and this should get you homeand help to prevent you from bending the front rim untill you change fluids.
Another use for GM Red ATF.
Those of you using a K+N or foam washable air filter.
Basically K+N filter oil is GM Red ATF.
So you can save a few dollars and by a quart of GM Red ATF and use it to oil your air filters.
dont under estimate 1 liter
04-05-2011 04:05 PM
driyac
07-11-2010 02:40 AM
