float bowls leaking - missing o rings?
Hey guys - first post!
Been working on an 89 hurricane on and off for a year. I've worked out my fuel pump and pilot screw issues, now I just need to figure out this fuel leak!
Leaking form the bottom of the float bowls. Tomorrow I will take the carbs off and investigate gaskets, the couple I checked were fine visually.
I also pulled out one of the overflow valves from the bottom of the float bowl and it was just the needle screw, no o ring, washer, gasket or anything. I read another post that sounded like there was supposed to be an o ring in there. Anyone know if I'm missing an o ring?
https://cbrforum.com/forum/cbr-600f-...l-seals-93052/
Good info in the linked thread, havent tried it myself but might be worth a try before spending the 20$ on each carb for the oem gasket kit.
You aren't the first person to puzzle over plugs.
This thread illustrates some of the trouble
https://cbrforum.com/forum/showthrea...ht=Spark+plugs
so 18mm is the answer, but it sounds like you will need a thin-walled socket if not a dedicated plug-socket.
cBrentb
10-21-2013 09:22 PM
