First Bike! 1988 Cbr600 F1 Hurricane Project
On saturday I bought a parts bike. Same year and model, just missing the headers, exhaust, and most of the wiring harness. I am in the middle of the engine swap, so far its taken about 5 hours to drop out both engines. What should I do tuneup wise to the engine before I swap it in?
I plan on painting the frame black, and getting an all digital instrument cluster. Along with a new front fairing from airtech.
Also I am trying to get the rust out of the tank that came with the parts bike, but I am so far unsuccesfull. It is a million times better than the tank that is currently on the bike so I reall y would like to use it.
I finally got the new engine in. Bolted right up once I lifted it in. Hooked up cooling system, wiring harness, carbs, fuel lines. Changed the oil, fresh antifreeze, and a battery charge.
First time attempting to start it..... blub blub blub blub with some exhaust coming out. hmm.... STARTER FLUID!!
squirt squirt click click VROOM!!!! blub blub blub.....WTF!!
charged battery, watched espn, then back to work. more starting fluid, blub blub vroom blub.
I kept hearing a swishing sound from the motor, not thinking to much of it.
Apparently the previous owned drilled out the screw that goes into the intake. there is the rubber gaskets that go from the carbs to the intake, then there are screws in the intake just below the rubber gaskets. they just plug the holes. so I put my finger over the hole and tried starting it. Roared to life. so Im not sure what I should do, jb weld it? the screw is shot to hell and will not come out. So is it necessary to have it open?
Love to hear suggestions.
Let the motor run for a few minutes, to work out the kinks. Runs awesome!
Took it for a little ride around the neighborhood, and everything seems great.
Except a quirk/problem I noticed when I first got the bike. The fuel pump tremors every second or two. Almost as if it is struggling to pull the gas from the fuel filter. So should I replace it? Or try cleaning it?
Thanks in advance for the advice.
People typically mount them in front of the other radiator. I've seen them directly in front with a small bracket or you can do something on the side like this:
https://cbrforum.com/forum/cbr-600f-...er-sale-66713/
