F1 Caliper Piston...
Old Jul 21, 2006 | 11:30 AM
franko!'s Avatar
Default F1 Caliper Piston...
Does anyone know the F1's front brake caliper piston diameter? I have looked for a F1 shop manual online, but have not been able to download a copy that I can view.
Thanks,
Frank
Old Jul 21, 2006 | 02:12 PM
rrasco's Avatar
Default RE: F1 Caliper Piston...
im not sure, but i have a manual and will try to look it up on my lunch break. unless michigan knows and answers before me.
Old Jul 21, 2006 | 04:22 PM
franko!'s Avatar
Thank you! I appreciate any effort.
Old Jul 21, 2006 | 04:39 PM
michigan_313's Avatar
good one...
i don't know but can find out tonight unless you want to field this one, rrasco.
Old Jul 21, 2006 | 06:17 PM
rrasco's Avatar
i will, as soon as i make it home.
Old Jul 22, 2006 | 01:00 AM
brian's Avatar
If Im reading this correctly its OD 26.918-26.968 wear limit 26.91 all in mm.Thats brake caliper piston outside diameter.
Old Jul 22, 2006 | 01:10 AM
franko!'s Avatar
Thanks!
I am guessing that the brakes on the F1 work well, but need more a lot more effort than the newer sport bikes.
(The master cylinder : caliper piston ratio is 14.8:1, just like my 86 VFR.BTW, the F4i ratio is 22:1)
Has anyone tried a 1/2" master cylinder on the F1? This would make the bike stop with less effort, but slightly more lever travel.
-Frank
Old Jul 22, 2006 | 02:10 AM
before i changed my master i had never noticed it needing that much more effort until the pads were wearing thin or the fluid needing to be replaced. as long as i had made sure that the system was completely blead, it always felt rock hard.
i replaced my master with a 2000 yamaha r6 unit (don't ask why i didn't use a later honda part, i don't know). the piston is 14mm but as far as lever travel goes, i'm using crg adjustables. it works quite well. also of note is that i changed out all my brake lines for ss braided lines. these lines over stock even with stock master was a great improvement in feel.
where abouts did you find the caliper piston ratio?
Old Jul 22, 2006 | 06:56 PM
rrasco's Avatar
well, guess you guys played ball first. fridays are my 15 hour days since i work two jobs so sorry for not posting up sooner. had the manual out and everything.
Old Jul 22, 2006 | 08:03 PM
franko!'s Avatar
ORIGINAL: michigan_313
Why did you replace the original 14mm master cylinder with a 14mm master cylinder? Was it to get adjustable levers?
As for the ratio it is a simple calculation:
Master cylinder piston area / caliper piston area
So 14mm dia = .551" dia, = .239 in2
The diameter of the piston is 1.06", ans we have a total of 4 = 3.53in2 total piston area.
3.53/.230 = 14.76
Look here for more info: http://www.vintagebrake.com/mastercylinder.htm
