exhausts for my cbr 600
check out ebay. D&D has a new slip on muffler you can buy from other vendors too.
http://cgi.ebay.com/ebaymotors/NEW-D...Q5fAccessories
heres an interesting header..
http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
delkevic has some slip ons on ebay too, ive been eyeing one but i have a supertrapp so im ok for now.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
also this setup comes with a black header.
Ok so i fixed the brake light problem..removed the brake switch and cleaned all the contacts...sprayed it all down with wd40...works like new now!
But I have a small coolant leak on the right hand side of the head where the radiator line goes into the head. very small pool of fluid under the hardline. anytips here? it doesn't looked damaged at all but im wondering is there a seal between the line and the head that maybe bad?
also the seafoam is having a really good effect on the motor..rode it last night for about 20 miles and it's running the best it has yet.
There is an O ring on that coolant pipe. Being an Aluminium Head, some corrosion builds up inside there and causes it to leak. Sometimes replacing the O ring can work, however I would recommend leaving the original O ring on there and picking up some high temp gasket maker (Copper Stuff). Take the coolant pipe out and put a small bead in front of the O ring and reinstall. Let it set up for about an hour then refill the coolant system via the cap under the tank. When filled, start the engine with the engine running, top up the coolant. Recheck after a few runs. Done and done.
